Beijer XTER T70 upload and modify ?
Ken Roach
Apr 2002
Seattle, WA
17,500
While I'm downloading the software, I figure I'll ask here since I've never touched one of these units before.
Can I upload an HMI project file from a Beijer XTER T70 terminal, modify it, and re-download it ?
I know I could expect to do this with some products (like A-B PanelView Standard) and not necessarily with other (like A-B PanelView Plus, or CoDeSys HMI).
What's the easiest way to connect a programming PC to a T70 ? I saw some Ethernet and USB plugs on the back.
Hi Ken,
Yes, it's possible to upload the application from an Exter panel (and modify/download it again). There is a risk that the original developer implemented an application password. In that case you need to know the password in order to upload the application to your PC.
Easiest is to upload the application via Ethernet. Default IP-address is 192.168.1.1 but you can see the unit's actual IP-address while the device is booting up.
At Beijer's website you can find several start-up documents that might be helpful, for an example:
http://www.beijerelectronics.com/we...ng=COM&DocID=FC538BE756AD560EC12577BB004455A8
Hope this helps!
//Supporter
That's excellent information. I'll make a visit to the customer site next week and see if I can upload.
Thank you !
You will need the software of course Ken. They do things a bit differently - I have been using their sunlight readable screens OK because I dislike Red Lion stuff immensely!
Hey guys,
Sorry for digging up an ancient post, but it turns out I need to do the exact same thing (upload project from T70 terminal) but the link provided for documentation is broken and I've been searching for quite awhile looking for info, but haven't found it. Hoping someone can point me to the proper documentation with a non broken link, thanks!
Thanks Parky, I was able to figure out that in the Transfer Window there are buttons for Send and Receive. Receive is obviously what I'll be using here.
Hi, I'm currently having an issue with a Beijer T70 HMI. We have 2 HMIs talking to a Yaskawa motion controller via modbus over ethernet. The...
598
Hi there, I have been working on a project using a small embedded controller called a SPLat (www.splatco.com) with a Beijer Exter t70 HMI. I have...
18
6,967
Spent the best part of the day trying to figure a problem with the Beijer Exter series no protocol mode. I got it sussed and so thought I would...
3,341
Does the Beijer Exter support PID blocks using the CLX (compactlogix)driver & using the L5K import . CLX Ver 4.15
1,844
Hi Is there anybody on this forum who worked on Exter Touch Screens from Beijer Electronics. More precisely with the controller data exchange...
5,959
