Bench Scale RS-232 protocol converter
Ken Moore
May 2004
North, West, South Carolina
3,476
Hey,
We are looking at putting in a World WEIGH C300 Bench Scale. It has a RS-232 port, that I assume send ASCII data to a printer. We need to capture this data and historize it in our OSI-PI Historian.
Redlion has the ICM8 that is a serial to ethernet protocol converter, but is is only for Red Lion panel meters.
Does anyone else have anything like the ICM8?
In a perfect world, a stand alone device would convert the weigh data to a number, (integer with implied decimals or Float). and send via OPC or Modbus.
I could live with S7 connection or Ethernet/IP too.
I have used ATOP serial servers in the past, these were pretty good, I used them with some PLC programming tools & OPC servers.
I would grab a Red Lion Data Station Plus any day for this application.
Their drivers and the C-like Crimson Program language gives you fairly easy and flexible serial string data, parsing, and translation.
And you can then present it on a virtual HMI, or log it into a file, or present it as any one of dozens of industrial protocols.
I have been a Redlion fan for years. I have used the data station for protocol conversions, but never used them with strings. I think I will recommend we buy the data station plus.
I'm going to recommend a Red Lion also. I've done this application alot. Parsing strings isn't that bad at all.
hey guys! were looking to purchase a new bench scale and have it integrate into our plc5. we want it to be ethernet/ip (were using a side...
2,718
Hi all, I have a AC current transducer that I want to bench test to ensure I am getting a 4-20mA output. I am using a AE001 unit. It is very...
126
was trying to use Connected Components to connect to a 525 drive via usb with the face off but can't seem to connect to it. the screen lights up...
817
So I'm using CCW to program a panel view and this is not my first I have done many. My Problem is I get an error message that I have never seen...
509
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,299
