Best Practice New computer Install?
jasil
Jun 2012
Building
48
We have new computers weeeeeeee lol and a lot of Rockwell and other software to install.
The "other software" is no problem, but Rockwell what are you guys doing when you have 1/2 older stuff RsLogix V15-20.01 with some SLC 500 etc as well and 1/2 newer stuff V22-25 ?
Are you doing 2 VMware sessions 1 XP and 1 Windows 7? Or 1 VMware Windows 7 utilizing Virtual XP to run the old stuff?
I like the thought of having one VM session.......I probably have 7 now, but since we are trying to standardize this I'm just wondering what current best practice is.
I called Rockwell they advised Windows 7 Pro and using Virtual XP.
Are you an integrator or in house engineering and maintenance? That makes a lot of difference?
How many computers are we talking?
Do you have volume licensing for your windows OS?
As an integrator I want to have lots of VM's for different software configs because each customer I go to may be using different version of Logix and FT View and other packages.
If I am an in house guy I should know what I have and where it's at and what versions I am running so I can use that info to determine what versions I need and what is compatible and how many VM's I need.
I run noting but office on my host and everything else in a VM. I like to put Rockwell and Siemens and etc. in a VM of it's own then in each brand I may have a VM for Logix 5000 to cover the version I need and a version of FT view that I need or multiple If I support multiple version of FT View.
The point I am trying to make is it's very dependent on your needs so it's hard to make what someone is is doing work for you.
I agree 100%................a guess a more specific question is why is Rockwell saying use Windows 7 with Virtual XP versus 2 VM sessions?
Has anyone had problems using Virtual XP?
I'm in house we use VM for Siemens, Automation Studio, and Rockwell. It would be nice to just have 1 VM session for all things Rockwell if possible hence the question.
I use two VMWare virtual computers; one with XP SP3 for the older software, one with Windows 7 Professional for the newer software. The host is Windows 7 Pro 64-bit.
I've only used "Windows XP Virtual Mode" in Windows 7 once, and it was such a pain to keep straight which folders and users and permissions belonged to which OS, I gave up on it.
For Rockwell software we actually have 3 VM's.
One is Windows XP for RSView 32 and Panelbuilder, one is Windows 7 64-bit which has every other piece of Rockwell software installed and is most commonly used day-to-day, the final one is a linked clone of this Win 7 64-bit VM specifically for installing Studio 5000 V21.03.
Rockwell software all the new stuff seems to run well on windows 7 pro. Runs 500 , studio 5000 etc. I also have an XP VM for some of the older stuff which I don't use very often I sometimes run a 500 simulator which seems to run better on XP
I'm getting ready to set up a number of Dell-type computers for use as HMI terminals. I'm wondering if anyone has any 'best practices' in this...
20
7,010
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
500
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,151
Had a philosophical discussion with a colleague of a related discipline today and I want to get the opinion of the folks here. The most common...
2,597
Hi, I am looking at the setting up some new ethernet comms which is originating from an SLC 5/05 to four new identical CompactLogix L24ER's...
2,543
