Best screen for Ignition designed HMI
Nebul0us
Dec 2015
Spokane, WA
125
I am looking at switching over from FTView ME to Inductive Automation's Ignition software. It's needs Java and although I see PanelViews can be loaded with vnc viewer software to remotely display the client, I would rather try a screen that can natively run the client.
So I am looking for suggestions on good screens to run ignition clients on. Thanks for you help!
Pretty much any PC based computer will run it. I've even tested it and it ran on a thin client naively....wouldn't recommend it for large applications.
We usually use panel mount Hope Industrial Touch screen 19 or 20" with an HP Thin Client mounted on the back of the screen
Multiple Projects coming up with lots of Touchscreen development. Am I the only one that finds the Panelview and Factory Talk ME to be severely...
4,226
Hi, I have begun using screen video capture software to diagnose problems where have many windows open at the same time, with things happening in...
4,633
I'm wondering if anyone has any suggestions on how best to display SQL data on an RsView screen. As the operator is processing a batch we're...
4,136
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
497
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
611
