bit reset problem Omron NT20s
robl
Sep 2007
The Netherlands
I use the omron NT20S touch screen to control a system that must "open" and "close". At each end there is a feedback to an input from the PLC (omron cqm1h-cpu52).
On the NT20S I programmed two buttons: "open" and "close". I used the alternate function.
If a press "open" the bit HR30.02 is set. If the feedback is high (open switch reached) then I reset (in the PLC programm) the bit HR30.00. Then I can see in the NT20S that the bit is reset (feedback light goes off).
And now the problem: I can't use the "close" button until I press the "open" buton once. So I think that the NT20S still remembers that I pressed this buton and not press it again to reset it because the reset is done by the PLC.
Does anyone have a solution for this problem?
Thank you for your reply.
I tried your solution and it works. Is it a bug from the NT20S that the alternate function does not work properly?
Hi Guys, I'm having a weird problem that I don't understand. The problem is that a bit needs to be transferred via DP/DP coupler with a sensor...
28
5,937
Hello Everyone!!! Dear Experts:beerchug:, I am new to Siemens WinCC:huh::confused:. I have created one Internal Tag 100_XV_01 (Unsigned...
10,570
I'm starting to learn some basic ladder logic. I'm on an AB Micrologix 1000 PLC. I'm wondering if the OTU instruction will work on an entire...
2,124
Hey everybody, I need help again. I'm designing a production display monitor with a red lion ProducTVity station. I'm displaying some counters...
2,624
Hi all, It is a Siemens question again :) I want to turn a bit ON in Ladder logic to be used as trigger to run a VB script. Then VB code will...
5,121
