Bit_Array_Code
mangesh.kolte
Jun 2015
Mumbai
Hello everyone....hope you are all doing fine..
Does anyone give me scan bit array example logic or code written in STL using any pointer ?
or
manual where i can understand scan bit array function?
Thanks in advance...
The analog array has 16 individual bits and each bit is an alarm. SCADA is having issues getting the BIT bool value. However they can get the...
1,041
I am having to manipulate MB data in a compactlogix 5380. I need to copy the bit array from the TCP MB master into a matching bit array to use in...
2,547
Hello, I am converting a Panelview 1000 to a Panelview Plus 1000, connected to a MicroLogix 1500. When doing the conversion, I received a Bit...
3,261
I'm having trouble with alarms coming across from a micrologix 1500 to a Panelview plus 6 600. This is a conversion from a Panelview standard to...
2,517
1. where can I check on Panel Builder, to see whether a bit Array (N10:56/2) starts from 0 or something else? 2. How do I create expression list...
1,491
