Block Data transfer Error No Module Exists
remington
Feb 2009
sd
Hi everyone, I have a plc5 with 10 block data transfers and I have two of them that when I go to the setup screen I get an error that reads "NO MODULES EXIST IN THE IO CONFIGURATION FOR THIS R/G/M". I assume that it needs a configuration for the card? If this is correct where can one locate it? Any help would be greatly appreciated.
Thank You
Unlike RSLogix500, the I/O configuration in RSLogix5 is for documentation purposes only. It has no effect on the PLC.
Now, with analog cards, it is possible to use the I/O configuration to access the setup wizards once you fill in the information for the block transfers, but aside from that it has no real function other than documentation
Paul
EDIT: See this thread for more info about how to access analog module configuration screens. In post #7, there's a backdoor method that should allow you to get to the I/O configuration without having to manually enter the BTR/BTW information...
Its just a warning. You can complete the programming without it.
If you want to get rid of the warning then under the project tree double click on I/O config. Select the chassis ( double click on it) then add the module you have in the correct slot. See picture below.
Edit: okiePC types faster then I do. I haven't had my Wheaties this morning.
Thanks Guys,
I am now able to see configuration, I saved it, but I still cannot use setup screen button without getting the warning. It is not a big deal going through IO config and double clicking, at least now I can view data.
Another one for Simon! This is related to the BLOCK_DB question in as much as it's the same program. I need to pass over the Cell address in the...
3,896
Hi... I'm new here and also new in plc world.... And I'm also not very good in english... I just want to ask about how to tranfer several data in...
3,859
Afternoon, I have a DB in TIA Portal V16 that is optimised. I cannot change this. There is an array inside that block which consists of 3000...
1,154
Hello all, PLC-programming noob here. I have multiple clients accessing some data on my Siemens S7 1211C PLC; some OPC clients and some direct...
30
8,340
Hey people, I have been using GET_NAME , GET_IM_DATA and ModuleStatus FB to get an info from Modules inside my program, but ever since and...
2,559
