bottle line simulator
amhd90
Sep 2015
Beirut
68
Can someone explain to me why thelearningpit use 3 bsl in parallel, and why the input are like this. And how if a bottle is defected in the start of the line, it will be remove in the end of it ?
Then can someone help me by explaining why the input of BSL are like this ?
Thank you.
I am not familiar with thelearningpit example but the reason for 3 different inputs will allow three different sensors located at different points in the process to work independently. You could also adjust the length in each BSL to have different reject points in the process or different locations for each type of reject. The independent inputs could also be used for totalizing how many of each defect there were. To remove a defective bottle you could use a compare equal of a constant and the value in a particular BSL "B" file to determine a reject status or you could simply use the "1" bit state in the particular "B" file to turn on an output for the reject device. Trying to explain this thru the written word is kinda hard, just watching the code work is easier.
If a bottle is small so b3:4 per example is 0, how in a later point of the simulation a sensor detect this specific bit and take the bottle into other line of production ?
I:1/6, I:1/7 and I:1/8 are located on the same place but at different levels, I:1/6 detects all normal bottles ( and apply to all bottles), I:1/7 only detects large, and the other detects only broken. This is my guess.
There is no other sensor. I:1/7 puts the size information into the BSL so the machine can 'remember' the state of the item at the time it was sensed and act upon that information later. If four bottles pass the sensor and they are large, large, small, large then the low four bits in the shift register will be 1101. the 1s and 0s will control the divert downstream.
In the zip attached is the ladder program I made to control the bottle line simulator. Please I need help and to know, how can I keep 1.the run...
2,396
Hi, I am new to PLC programming. Myself and several co-workers are taking a PLC class and we are using the logixPro to learn on, Our problem is...
20
24,474
Hello, I am trying to solve the bottle line simulation, but I can't understand the basics, and why we are using BSL and BSR, so can anyone provide...
2,968
[OSR] Using BSL instructions When working on rslogix.pro lab (bottle line simulation). Lab exercises 1,2,3,4 worked fine. However, when putting 3...
43
19,987
Hi everyone! i got a problem in creating the flowchart for my Bottle Line simulation system. http://youtu.be/om5DGgxdmaU i used "Bit shift left"...
3,867
