Brabender DL-4000 to SLC 5/05
B Fix
Nov 2008
ND
17
All,
I have a customer that wants me to message between a SLC 5/05 processor and a Brabender Congrav RC4 using a DL-4000.
Do I use the SLC cable that is used to connect my PC to the SLC channel 0 to connect the DL-4000 to the SLC 5/05, or do I have to use a different cable?
I was sure cause I know that for my computer to see the SLC on channel 0, I need the special cable and I can't just use a normal one, so I was just wondering if I still need to use that special cable for the SLC to DL-4000 connection.
Thanks!
All,
Thanks!
Yes, nothing special just a null-modem cable.
I have 16 cb_E connected to OP16 via fiedbus and the cb-E connected to l60 controllogix via en2t ethernet. using generic module in IO config so I...
1,738
Hi All, I'm setting up a Brabender feeder via Ethernet I/p, I have the start and stop figured out but the int to real has me up against the wall...
2,834
Hello Friends We have 10 Powerfocus 4000 with DeviceNet, We need to backup the configuration, the Powerfocus is detected but as unrecognized...
126
Hi, as part of a project to bring an old retired power plant back on-line we need to access a single existing TT4000 HMI used to interface 2 Solar...
474
who can teach me how to edit tag adam 4017+ in citect scada? real external I/O
885
