branded 4-20mA or 0-10VDC simulator
imranali
Jan 2011
islamabad
i want to supply eight 0-10VDC inputs(variable) or 4-20mA current signals to my allen bradley PLC for testing purpose before giving it the real signals from field..can somebody give me the name of any such card by a well known company..as i will test it extensively..thnx
Fluke have loop calibrators that you can use. However these are quite expensive and if you need eight of the you will get ruined.
If you have no requirements for accuracy you can probably weld together somethings with variable sesistors etc.
Otherwise I would use Outputs from another PLC. Maybe you have one around.
As a quick and dirty voltage source flashlight battery or other dry cell work well. If accuracy is an issue use VOM to measure the voltage while under test.
For current use a resistor in series to obtain a desired current. Again a VOM can be used to get accurate current reading.
As an aside I have used 9V batteries to determine if small DC motor will run - dont last long and get warm but for 10 second bench test they are fine.
Dan Bentler
well thanx..bt i had already used these resistors and personally welded things but they dont work too fine..i want to include this test system in my original system for time to time testing and calibration..and need a branded thing that can last for years..e.g. something from ABB, AB,Seimens or any other well known firm..
We use a Yokogawa Calibrator...
It is a really good and easy instrument to use, although I don't think that it would be any cheaper than the Fluke, :).
Link here.
The HMI is a re-branded Red Lion G315 (Eurotherm). The project is adding a small, inexpensive PLC, with a handful of discrete IO, and 2, 4-20 mA...
6,067
I've brought this up before, but did not come to a conclusion about what to do. I have a large number of tags used on a re-branded Red Lion HMI...
3,939
Hi, I am working on a project in which, we have a requirement to connect multiple PLC's with WinCC scada. The scenario is that we have multi...
2,974
Hi I currently got a system with 2 Siemens KTP600 mono running with a s7-1200 plc for a pumpsystem on a fish carrier. But the customer didnt like...
1,856
Is there anyone that has any clues around the hardware for iX-plattform? Is it rebranded or self developed? I have some clues that the hardware...
1,360
