Bridging Modicon Quantum to Momentum via Ethernet?
swany1613
May 2012
Michigan
Hi all this is my first post on this site. I am currently interning at a company as mechanical engineer but one of the projects I am envolved in has me touching on the plc world. I have been doing a fair amount of searching and reading but to no avail I have not found my answer. So my question is, Is it possible to bridge a Modicon Momentum by ethernet to a Quantum? If more information is needed I can add but if it can be answered I would greatly appreciate it. Thank you.
Don
Yes, if they both have Ethernet ports. Both products have configurations that support Ethernet, but it would require that the parts you actually have support it, or you are willing to upgrade as needed.
Well I guess I should have stated that the Quantum is connected to the plc through MB+ and then the plc is connected to to the HMI through ethernet.
hello, I have a problem with my AN-X2-AB-DHRIO Prosoft module, I can't connect with the module because I lost a microSD card that has firmware and...
388
Can anyone help me if i can use or if it is possible to use any of AB stratix devices for network bridging? .. We are planning to communicate...
1,658
This seems more as an IT problem but it's related to PLCs so I'll give it a shot here. So to connect to PLCs I now use very long Ethernet cable...
2,296
I feel kind of dumb, because I swear I've done this before, but I can't seem to remember how I did it. I want to do a PanelView Transfer via...
2,047
Hi everyone, I'm currently trying to connect to a VFD PowerFlex 70 which is in a two ENBT Backplane, one ENBT within 10.xxx.xxx.xxx and the other...
1,383
