Buying A PLC: Help!!
Sep 2008
Mississippi
I need to find an Allen Bradley PLC, and an Automation Direct PLC with the following stats:
- 64 inputs (Discrete)
- 32 inputs (Discrete)
- 1 analog input
- 1 analog output
- Housing and all cables necessary
Anyone got any good sites or webpages that i might be able to get some prices for a PLC matching these stats? Thanks.
- 1 analog input
- 1 analog output
As far as the AB hardware goes, a MicroLogix (check for expansion slots for correct model) will do the job but I would spend an extra buck and get the Low End CompactLogix (L23 I believe, just released).
www.ab.com
bernie_carlton said:
You did not mention programming software and cables. That may be a consideration.
I assume they must have both packages.
That's why they would be looking into aB or Automation Direct.
Good point Bernie! Software and programming cables will add up to the budget.
Hi, I have been trying PLC simulators and reading on PLC but i think i need some practise so i am planning to get a used PLC off ebay and create...
21
6,155
Hi ALL, New to this forum What I'm looking for is information on where to buy new or used PLC's to practice on. I'm in Ontario Canada so I am...
5,501
Hello all I have the opportunity to buy some second hand unused components, they are Siemens motor modules, a CPU, inputs and outputs. I have...
2,182
I was interested in purchasing Studio 5000. Non subscription based, if possible. I was given a part number of 9324M-RLDT30. Is this a good...
6,562
Hi, I am interested in buying a Siemens starter kit. I came across this site, realpars.com Does anyone know if this is a reputable company?? Any...
1,187
