hey folks,
I am just new in the industrial world so bear with me. I have rslogix5 and i have a input signal which i want to bypass. If this signal was used only at one place i would just put a branch around it and it would work but i have input which is used many times in different routines. Putting a branch around will take a lot of time. I am not sure is forcing the answer .For some reason rsl5 makes it sounds very dangerous . How do you exactly force it. Will it affect others inputs if it is forced since i see the force values for all input. Also about analog inputs.Last what is the difference between forcing on and toggle bit both will make the bit one . So what is the difference
