Passing arrays into AOI
nehpets
Mar 2009
Wales
496
My first real attempt at utilising the AOI function in Compactlogix.
The issue I'm having is, I have an array of INT[400], but in my AOI I'm only using INT[20], therefore I need to offset where in the INT[400] each subsequent AOI reads from. Is this possible straight out of the box?
I hope i've explained clearly enough.
Steve
Is it always 20 that you use? If so, just add a StartOffset parameter in your AOI. Limit/Shape the StartOffset from 0 to 399 (or SIZE) before using it, so you don't fault your processor, and then copy 20 members from StartOffset to your internal INT[20].
I'm using FactoryTalk ME version 13. I'm aware how to pass a parameter file once, but I was wondering if it is possible to do it twice...
159
I inherited a project in which a ME application displays process measurements (temp, pressure, flow, etc) on a PanelView Plus display. The data...
497
Hi guys. Sorry for the dumb question but I am still new. I have learned to pass Parameters using an HMI tag so far. Can I write directly to the...
921
Hi guys, A dumb question, but is it possible to pass values to tags using parameter files in Ftview SE ver 11? TIA
1,466
Is there anyway to pass a parameter file without using a Go To Screen button in FactoryTalk View ME? I am currently using multiple Go-To buttons...
1,631
