C200H ->CIF01-> CJ1M
The CPM1-CIF01 is not designed to work with the old C200H.
That connector was ONLY for the handheld programmer C200H-PRO27
It will work with C200HS, C200HE/G/X, CPM1 and CPM2 series products.
The C200H-CPUx require a Host Link Unit.
Rack mount is C200H-LK201 or cpu mount 3G2A6-LK201
Hope this will help.
Big thanks!
gtsuport, can you give me information about you? Where you work, how long you use OMRON controllers? Its necessary for my account to guidance. I understand that my request is impudent and you can leave it without answer. sorry for my bad english:)))
p.s: if you will accept we can correspond thru private messages
I work for an Omron distributor in the United States.
I have been working with Omron plc's for about 20 years.
Just let us know if you have any other questions.
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
727
In order to upgrade a control unit, we need to backup program of an omron C200H CPU01 with host link LK202-V1 that has RS422 D9 Connector. Please...
629
Which software and cable to connect to plc omron sysmac c200h cpu01 ? Thanks
1,940
The logic seemed to convert nicely, and I had to make changes to the addresses for my AD and DA and 32-point input cards. The current problem is...
1,044
I am trying to display some scaled analog input values on a C-more Micro terminal, from an older C200H Omron PLC. The addresses appear to simply...
2,187
