Calculation Using Vijeo Citect Cicode
HendyPratama
Apr 2018
Indonesia
Dear All,
I have a case for calculating the variable tag.
I use Vijeo Citect By Schneider Electric for programming.
i want to calculate 1 variable tag by using cicode editor
example:
one variable tag sending to microsoft access database with event on vijeo citect every 10 minute, i want to calculate every 1 hour. 1 hour is six time send to microsoft access.
how to calculate variable tag to 1 hour.
please help me to solve this problem. :nodi:
Thanks before Mr Sigmadelta..
using event in vijeo citect is not problem..
data sending to ms.access every 10 minute.
problem is, i want a total of 2 data from 6 data sent to ms.access.
example.
data send on 16:10:00 is 20,
16:20:00 is 80,
16:30:00 is 40,
16:40:00 is 30,
16:50:00 is 20,
17:00:00 is 10.
i just want to add up the data at 16:10:00 and 16:20:00
how to add the two data?
this is one of the assignment that i have been given in my training course, i really don't understand the way to do the calculation required for...
11,596
I test about winder machine.I use linear velocity and winder shaft rpm calculate</SPAN> diameter.But I found when the linear about 5m/min,the...
2,448
I am having trouble believing how complicated this is. I'm using CLX and I wish I could find some sample code or easier formulation to calculate...
8,353
Hello everybody, I believe that I will find experts here who have already solved a similar topic. I need to calculate the length of the...
346
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
116
