"CALL"-GE fanuc 90-30
Apr 2011
Manila, Philippines
295
good day experts,
We have a problem regarding the modification of program:
Here's the scenario:
PLC: GE Fanuc 90-30
CPU:374
Module: IC693MDL645
Originally, we have an LD Block "CSS1"
our boss order us to modify the program that leads us to create a new LD Block named "CSS2"
some variables from CSS1 were used in CSS2, also we added new variables..
Here comes the problem:
validate: ok
download to CPU: ok
we try to activate the switch (expect to turn on internal relay %M0003)
but nothing happens.
we try to force on the input but still nothing happens...
ALSO...the math functions aren't executed, (parameters were met)
Any idea about this problem??
Mr. Steve told me that there is a possibility that the new LD block "CSS2" was not recognized or "called"....
How to call an LD block so that a new LD block would be recognized??
Thank you guys!!
P.S.
searching for manuals and topics regarding this one...:mad:
I have programmed a GE-Fanuc 90-30 PLC with a 313CPU. This is the first time I have programmed a Fanuc PLC and the first time I have used...
7,260
Hello everyone. I am working on designing a call light/alarm system I have roughly 20 stations that will each have their own call switch. Then...
20
490
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
142
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
692
I created this FC and it compiles, but when I use it in my MAIN OB1, it appears to have two outputs. See pictures. What am I doing wrong here...
1,487
