Cam lock hose sensor as an input
Jim G.
Nov 2007
Georgia
187
We have a system where we are pumping glue into a circulating tank from the production line. The glue runs out of a drain pan through a hose to the circulating tank where it is recycled. The hose has cam lock fittings on each end for connecting and disconnecting means. If we have a product change and switch to a different glue type, the operator must switch the hose out with a different one and connect to a different circulating tank. We have to do this because there is only one outlet from the machine. The concern is that the operator will change glue types but forget to change over the hose, and cross contamination will occur between the 2 glues. It has been requested to install some sort of electrical interlock to provide an input to the plc so that programming can be done to prevent starting up on a new product without everything in its proper place. They want some sort of switch on the cam lock to detect a connection or non connection. Does something like this even exist?
I am open to other means of accomplishing this.
Thanks.
With 2 types of glue you may want to add something to sense which hose is connected - not just one was disconnected and reconnected.
That could be as simple as putting a magnet on the hose to one glue with a magnetic proxy sensor on the machine along with the above sensor - then you know that a hose is connected and which one.
If f.i. the slave axis has to start the camming not from the beginning of the cam but somewhere in between, the parameter 'cam lock position' has...
1,433
Hello all, I'm looking for ideas or solutions on having a industrial webcam or IP camera that we could use on our equipment to help monitor and...
1,222
Kindly, I was trying to use the Motion Arm Output Cam (MAOC) instruction on a Rockwell plc, but I need to have it in a general AOI function. So, I...
1,041
If a polynomial is used in a cam-profile for motion control, you normally have the option to displace the inflection point from the standard 0.5...
1,448
I have submitted this tread to a magazine and it got rejected by the editor that obviously has never done motion or used cam tables.
2,133
