Inflection point in polynomial cam profile
aand74
Dec 2005
Deinze
131
If a polynomial is used in a cam-profile for motion control, you normally have the option to displace the inflection point from the standard 0.5 (symmetric) to a value between 0 and 1. What could be good reasons to displace this inflection point? Is this done often?
A third order polynomial can have 2 inflection points.
What do you mean by 0 to 1? The distance between points can be anything.
What are you really trying to do? You have asked questions about target generators before.
Usually an inflection point is a place where the maximum or minimum position or velocity occurs. It is wise to check if the maximum or minimum position exceeds the positive or negative limits.
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
75
I have a bunch of tags in Historian/VantagePoint that off by one decimal point. I looked into the HMI displaying the same number, and the HMI is...
117
Good morning, I have a Emerson/GE PLC with Cimplicity SCADA. I need to export data of a specific point/object to a CSV file and load the CSV file...
287
Dear We are working in AB Studio 5000 and the drive is a PowerFlex 755T. For this project I need to control a conveyor to a certain set point...
146
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
266
