can i create a mantissa ML 1000?
khewes
May 2016
New Hampshire
123
Goodmorning Everyone,
I am new to PLC programming, and I continuously come across limitations with my Micrologix 1000 plc controller.
Currently I need to use float numbers, but my controller does not support this. i was wondering if the mantissa applied to all binary numbers, or if it only applied to certain software driven binary? any ideaS?
Micrologix 1000 is obsolete.
I dont think there is an easy way to achieve floating point math functionality with an ML1000.
The best I can think of is to stay with integer math, eventually with shifting of the decimal point, and careful testing against crossing of the integer boundary limits (-32678 .. +32767).
If the above is not a satisfactory solution, how about changing to a newer PLC that supports floating point math. Yoy may find that it is quite inexpensive, and you will enjoy other good things such as online editing, more memory, faster processing, more I/O, etc. etc.
Agreed, drop it for a ML1400 and save hours of headache. It will pay for itself easily vs trying to program some half-baked floating point math with integers.
Yeah. i was at a dead end with no where to go. I just got the go ahead to spec out a new plc. Everything here is Allen Bradley so I want to stay consistent. Is the ML1400 the way to go?
If you are staying with a platform that is programmable with Logix500 then the ML1400 (orML1100) is the way to go. In fact, for Logix500 platforms, it is the only one I would use.
Consider making a step u and standardizing on the ControlLogix platform. For a while we were using both, using MLX on small systems, but with the newest small compact logix models we have quit using Logix500 platforms for any new work and have phased most of the existing MLX and SLC PLCs out.
Aside from the initial cost of Logix5000 software, the CompactLogix is economical enough for small systems. If you already have Logix5000 software then for heavens sake, quit using SLCs and MicroLogix.
Do you mind sharing what 5000 processor you're using to replace the MLX? Last I looked, some of the L1 compactLogix had comparable costs to a ML1400 but always had some severe limitation, like only being able to have 4 expansion I/O or something like that. Are there better options now, or do you not usually run into those limitations on smaller projects?
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
253
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
159
Good morning to all, I have the following issue, I installed everything of intouch including the patch, it is the 2023 version. The...
338
So, I finally got versioin 27 installed on my Windows 10 VM. However, now I can't upload a project from my lab controller. I have the above error...
1,133
Hi all, I have few GB of logged data created by RS View 32 Works, it is all in .DBF format. At the moment, my company wants to shift all data to...
1,465
