Can I directly change 1734-ACNR to 1734-AENTR?
Yashka
Nov 2019
WV
91
Hi All!
I have inherited some system based on ControlNet coax. I'd like to upgrade it to EtherNet/IP. So, can I just buy the 1734-AENTR instead of the currently used 1734-ACNTR and just replace the ones in the racks? Or should I do something additional to changing the IO configuration in the project?
Thanks in advance!
The adapter in the project will need to be changed. I would create the new ones, search and replace the IO, then delete the old ones. Then download.
If your CN adapters have a unique name you want to keep, just make the Ethernet one with a NEW after it. Then when you delete the CN one just rename the Ethernet one.
Also after changing over make sure to document and apply any configurations to IO cards. Like analog scaling or point defaults.
I've got it. Thanks!
Hi; First of all, I am sorry that my post is not relevant with this forum. I have recently purchased Samsung cell phone. I have alreay saved...
77
Hello everyone!!, I may be asking a newbie question, but I want to be sure of that. Can I run a PLC program directly from the SD card? I mean, I...
194
When using System Platform, I can use the object viewer to directly manipulate attributes/tags/whatever. When I have a standalone InTouch...
996
As I understand it, Codesys is the foundation for many different OEM branded HMI software packages. What are the advantages and disadvantages of...
1,649
Hello, I was wondering if someone can help me solve how to use a MSG instruction to get the data and fault information from an ControlLogix I/O...
57
13,759
