LuCyLut Member L Join Date Jun 2006 Location Michigan Posts 5 Oct 5, 2006 #1 Hi Everyone, I was wondering if I'm able to use Panel View 600 for display from the MircoLogix 1100? If not what can i use? thanks in advance! Lucy
geniusintraining Lifetime Supporting Member + Moderator Join Date Jun 2005 Location SC Posts 8,280 Oct 5, 2006 #2 You can find the answer in the manual, I think pg 160ish, you need to look up the P/N of your PanelView and check what communication options you have, you may need a AIC depending on the model http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2711-um014_-en-p.pdf
