Can memory be damaged by power cycling of machine online?
Peacemaker
Feb 2004
22
Hi guys, a couple of days ago I found my laptop's memory module was damaged after using laptop onlne with micrologix controller. I remember I did power-cycling a couple of times with interface cable connected with MicroLogix controller. After normal shutdown I tried to start my laptop but there were just beeps and nothing happened. Found memory was damaged. Now my laptop is OK.
Can memory module be damaged by power cycling with electrical shock through interface cable? Or this is just a coincidental. Actually this interface signal is not isolated electronically. I used a aftermarket cable. Is there any eletonically isolated interface cable employing optoisolator?
Any feedback would be much appreciated.
This reminds me of a joke.
A software engineer, hardware engineer and departmental manager were on their way to a meeting in Switzerland.
They were driving down a steep mountain road when suddenly the brakes failed. The car careened out of control, bouncing off guard rails until it miraculously ground to a scraping halt along the mountainside. The occupants of the car were unhurt, but they had a problem. They were stuck halfway down the mountain in a car with no brakes.
"I know" said the manager. "Let's have a meeting, propose a Vision, formulate a Mission Statement, define some Goals, and through a process of Continuous Improvement, find a solution to the Critical Problems and we'll be on our way."
"No," said the hardware engineer. "I've got my Swiss army knife with me. I can strip down the car's braking system, isolate the fault, fix it, and we'll be on our way."
"Wait," said the software engineer. "Before we do anything, shouldn't we push the car back to the top of the mountain and see if it happens again?"
I would probably take the programmer's approach... :)
Seriously though, It was most likely the fault of the cable. I've had static take out the program (but not damage the memory card) of Series Sixes when plugging in the programming cable.
So, yeah, it can happen.
Yes there is, a 1761-NET-AIC+ see pdf below.
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
67
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
329
I have a c-more micro with a three digit input box on one of the screens. This is being written to a memory location in a DL05. I don't have the...
111
Hello PLC friends. I've been going through a saga of diagnosing and fixing an old PLC setup that I inherited. I am learning as I go. Initial...
337
Hi folks ! Got an older Modicom BM85 and I suspect that it's not passing data to ModBus+ network. We had a power loss for a few days and I suspect...
68
