CAN messages J1939 using Beckhoff CANopen terminal?
g.mccormick
Jul 2012
IN
961
Does anyone know much about CAN communications? I potentially have a need to get data from CAN based NOx and NH3 sensors (these are typically used on diesel engines). I need to get data in, do minimum logic with it, then stream the data out on a RS232 serial device to a third party device.
Beckhoff has a CANOpen terminal and it sorta mentions a bit about general CAN messages and built in protocol implementation.
https://www.beckhoff.com/EL6751/
Anyone have thoughts?
I wrote a J1587 parameter decoder for a company recently. J1587 is an older protocol with a lot fewer parameters than J1939 but similar. J1939 uses a PGN/SPN Parameter Group Number/ Suspect Parameter Number format. This data comes in from the engine diagnostics port. CAN bus is just the carrier. You will most likely need an adapter with the correct wiring harness to get the protocol converted to a bytestream. The setup I had was a laptop running my C# app with a commercially available adapter connected through USB to the laptop. The other end going to the engine diagnostics port. The data comes in as a byte stream and you will have to identify the PGN/SPN numbers. Also does that particular engine make those data available? The data you get comes from a central controller such as the ECU. The database for J1939 parameters is at least 18000 rows of data.
I worked in the well fracturing business for a while and we used an adapter from Monico that would inject J1939 data directly into Siemens S7 data tables, so there are options available. Hope that helps.
https://www.monicoinc.com/protocol-converters/j1939-engine-monitoring
That's a CANOpen module rather than J1939; it's not going to help.
I use Beijer X2 Hmi as a J1939 'listening' device.
It has enough intelligence to condition/pass on data itself, or the built-in Codesys PLC will certainly give you enough to play with.
Pp
For my application, it would only be 3 sensors worth of messages, not a whole ECM worth.
Beckhoff says that they EL6751 and/or CX8050 can be used for J1939 messages.
Yes it is possible to use the EL6751 and/or CX8050 to communicate to a J1939 device. CX8051 will not work.
To communicate to a J1939 device, use our “CAN Interface” or raw can mode with our CANopen master in TwinCAT.
You can use our EL6002 with our “serial communication” PLC library for RS232 communication.
I am trying to get Codesys to work with a couple of Moxa ioLogik E1200 series DIO devices (E1210 and E1211). I am able to write to the E1211 DOs...
185
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
737
Can I open a Port from a Siemens PLC to an ethernet device Device will be at 192.168.0.1 and I need to open port 2112 (Upd?) Then once the...
320
380
Migrating v8 FT View SE to v13, had to export tags because after v10 the configuration is no longer supported. Imported tags to new Tag Alarm...
518
