Can not simulate Two CPU with Plc Sim 5.4 SP3..
Jirrr
Jan 2009
Czech
167
Hello,I am not able to simulate two CPU with PlcSim,I have tried to use SFBs and CPU 400,I used Netpro to tranfer network configuration...but without success,is here Anyone who can give me some advice or provide any samle project that works?
Thaks You a lot
I have already read it,but it still does not work...I tried to use the same CPU and so on.So I need some working project to learn what I did wrong...
I am going to have the same problem. I am going to setup a Virtual Machine for each extra PLC I want to simulate, load XP in it, and just load the PLCSIM. You need lots of RAM on your host PC - 4GB, 8GB+. But I think each extra VM probably can run on 512K.
How to simulate 2 cpu using Step7 plcsim i tried with no success i followed this guide here...
90,837
Hello All, Is it possible to test Profibus connection for Data Exchange actual CPU and another CPU (simulated)in PLCSIM? If possible kindly show...
3,399
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
118
Hello, I have a small application with a S7-1200 CPU 1212 and a KTP400 Basic HMI. When i am connected to the PLC with my PC i would like to...
553
Hello everyone, i would like to test and run os server in pcs7 v8.2 project without rear PLC.i used plcim on ES and nettoplcsim and adjust the...
1,345
