can't communicate with a slc 5/04 processor
I'm lucky that the last job I did was at a site with an 1784-u2dhp that was going to be THROWN AWAY because it was the last site they had with AB PLCs and we just upgraded from it to Siemens.
Thanks, Mickey. I changed the link partway through. I also tried to post this link:
Automation Networks link
I can't edit the original post, now. The "Posting Rules" box at the bottom of the page says, "You may edit your posts" but there's no edit button...oh, well.
edit:
for some reason the link to the automation networks site won't work, no matter how I put it in. Just Google "automation networks DH+" and it'll show up.
There's a limited window of time after you post in which you can edit, 15 minutes or something like that.
Hello, first of all, I want to say thanks to everyone who is seeing this post. I have a problem with an SLC 500 5/05 processor. I need to download...
2,828
Hello. I'm trying to communicate a DOP-B07E515 HMI(DAKOL) with a SLC 5/03 PLC. The serial port connection rs232. I am using a cable with the...
1,053
Hi everyone, I have an AB 1747-L20B PLC that has a CPU fault, I am trying to connect to it with RSLogix 500 Pro to see what the fault is and to...
3,327
I have a SLC 5/04 PLC and CP3 cable and DF1 selected in RSlinx, when I do auto-configure it says failed to find baud and parity! check all cables...
3,024
Dear Friends, We have a setting machine in which 20 Parker Servo Drives and motors (name plate images attached) used to place the tools at...
3,897
