Cant connect to micrologix 1500
Goody said:
This laptop was used by the company to program these plc's and all of the plcs are connected by ethernet and rsview scada.
Mickey... the above is the reason for my comments about the Ethernet :confused:
Mickey said:
He has a ML1500 no ethernet port.
Mickey said:
OkiePC,
Goody, If you have the ML1500 LRP as stated in your first post , then try the other port. The one on the side. You will need a 9 pin to 9pin null modem cable
Thanks, Mickey, I got this post mixed up with another one in which the ML was cnonected to a NET-ENI...
Sorry bout that Goody!
QUOTE=geniusintraining]Mickey... the above is the reason for my comments about the Ethernet [/QUOTE]
Goody said:
thank you guys - I'm afraid it will have to wait while tomorrow now, its late here in UK and boy is my head throbbing :) :)
Time for a beer and forget all about plc's.
One day i'll be an AB man too :)
I think we need to take Goody's advice and go have a beer.
ah the morning brings a clear mind and renewed determination.
But I didnt need any because I open the front of the plc - pressed the comms reset button and the green dcomm light came on.
Suddenly trying to connect did not result in a furrowed brow and muttered oaths - it said configured and woah - I'm online!
Although this plc was still in the box with all the sticky paper still attatched - it had been programmed ready for a swap somewhere on the network. It isnt now though - its my plaything for a while :)
Once again thank you all for your help. Without it I would surely have failed and given up.
Every plc brand has their quirks and weird ways of configuring them - thats why forums like this do good business :)
I am sure glad it and you lot are exists :) :)
Goody said:
ah the morning brings a clear mind :)
You appear to take your beer drinking in moderation, I wonder if the other 3 that you convinced to have a beer, also do it in moderation,
I'm still drunk.... does that count as moderation :D
Glad to see you got it working Goody...
Yes, and I think your coming from the Mitsubishi world where all you have to do is select the proper CPU and guess the baud rate. I would say configuring the communications of a serial connection is the toughest hurdle with the AB PLC. While it's bad that it is the first thing a newcomer must do...but at least you get it out of the way early. Should be pretty smooth sailing from here.
All I can say is ,yes,yes,yes.
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
748
Hello Everyone i got a problem with Endress Hauser FlowMeter Promag W400, in his specification says it support Ethernet/IP protocol...
1,836
Hi all, we've recently shifted one of our Micro830 PLCs from one project to another, when loading the new program i was prompted to do a...
3,069
I have a PLC which students have been using to get to know PLCs, but it ended up in program mode. Most likely because they ended up taking the...
1,217
I am trying to connect to a 1756-L71S GuardLogix 5570 Safety Controller and it wont let me upload of download or even go online.I have checked...
21
8,537
