Micro830 cant connect after firmware update
45-Jacob
Mar 2021
Waikato
Hi all,
we've recently shifted one of our Micro830 PLCs from one project to another, when loading the new program i was prompted to do a firmware update, part way through after the unit reset itself (as part of the firmware update) it appears to have become unresponsive to the USB port.
i can see it under AB_VBP-1 but it doesn't let me select it (ok button is greyed out)
any help would be greatly appreciated
-Jacob
just thought id add i've tried resetting the firmware using controlFlash and it says that the device doesn't match the catalog number, seems the firmware has blanked what model PLC it is, is there a way to factory reset these PLCs?
reset within the firmware menu of CCW just tells me a similar thing about the device not matching the device in the project.
I am having issues getting a Red Lion HMI and Micro830 controller to communicate. I am using the cable here to connect the controller to the RS232...
117
Trying to put these equations in structured text program in a Micro 830. when I run the verify I get this error. ;:expected before this new...
440
Having to add some programming to a Micro830. I want to add a free running TON, reset with a done bit. in the drop downs or the instruction...
287
Hello, We have a project on our shop floor that for some reason project management decided to not talk to controls about and pick some...
1,322
I have an application using an A-B Micro830 controller. Does anyone have a PDF tutoring how to program one of these. Not very intuitive especially...
23
6,551
