Can't create MG file in SLC/505
rta53
Feb 2003
North Carolina
619
Ok I'm feeling really dumb right now. I was wanting to create an MG file in a SLC 5/05 processor. It is a 1747-L551C, OS501 Series C, FRN10. However in the dropdown list of available file types the only ones available are as you see in the attached image. What am I missing here?
I think that maybe you're confusing the features available with something like a MicroLogix 1400 (etc.) system with the features available with the SLC-5/05 platform ...
since they're both programmed with RSLogix 500 software, it's easy to forget which system you're working with ...
you can probably still do a Message command - but you'll have to use an "old-style" Integer (N-type) control block to make it happen ...
You are correct Ron. I don't work with SLCs that much anymore so I guess I had a brain freeze. Thanks for giving me a gentle reminder. :)
The PLC-5 controllers originally used blocks of Integer (N) data file memory for the Control blocks of MSG instructions, and later added the structured specific-purpose MG type data file.
But the SLC-5/05 never added that structured data file type. You still use blocks of Integer (N) data files. For Ethernet messages, makes sure you reserve 51 words for each Message instruction.
So, I finally got versioin 27 installed on my Windows 10 VM. However, now I can't upload a project from my lab controller. I have the above error...
1,133
Hi all, I have few GB of logged data created by RS View 32 Works, it is all in .DBF format. At the moment, my company wants to shift all data to...
1,462
Hi all, I need some help in uploading of QuickPanel gp570-sc21 program to PC. I load from QP to PC the project through the working HMI-CAB-C49...
2,030
Hello Dear Plc expert I can not create the project on studio 5000 or Rslogix 5000, If I chose compact logix CPU (1769 L18ERM BB1B) but If chose...
985
For Allen Bradley platform, without PLC, can I use an .ACD file to create a new HMI ? No physical plc and only have some PLC program. want to...
1,763
