QuickPanel gp570 "unable to create project from upload file"
Chocco
Jan 2022
Minsk
Hi all,
I need some help in uploading of QuickPanel gp570-sc21 program to PC.
I load from QP to PC the project through the working HMI-CAB-C49 adapter (I have been using the working one for a long time).
the download goes to the end and the error is "unable to create project from upload file"
Tried all possible QP selection settings, speed 9600 .CPU ABB 200 30/20.
Why this error appears is not clear. thanks in advance.
One of the security features of the Quick Panel was that the original programmer could choose to only download the compiled runtime file to the QP and not include the project file. When that is the case the end user can't upload anything from the HMI that can be edited. That may be the cause of what you're seeing.
Here's the text from the Quick Designer manual:
The Upload Project button is used to upload a project file from a Quick Panel. The project file must have been saved witht he downloaded file, otherwise an error message will appear.
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
345
Dear colleagues, hello to everybody! I have a problem with Quickpanel IC754VBI06SFD-GF Proficy Machine Edition Runtime 6.5 QuickPanel View V2.00...
665
Dear guys, I am not a programmer but I can do simple things myself. I'm stuck with the following. if I want to extract a value from my rx3i...
46
4,787
does anyone know if you can make a graphical panel with the quickpanel+ 7inch that you can only open with a password? for example a panel where...
1,825
Having trouble connecting and uploading from a Quickpanel View to Proficy Quickpanel communcates to PLC no problem Quickpanel IP...
2,460
