Cartesian Fluid Motion
dr_cronik
May 2012
United Kingdom
47
Hi All
Im trying to improve the performance of a cartesian Pick and Place system on our plant.
I intend to write a routine to move the robot to a position, which will be passed to the routine before it is triggered.
The basic operation of the routine will be to lift the Z axis to a travel height and then move X,Y axis on the horizonatal plane to the new position. With our current system the Z move completes (.PC) bit on before the horizontal movement is triggered, this results in a slight pause before movement continues.
I would like to merge the vertical lift move into the horizontal move before the final Z destination is reached. The point of merge will be dertermined by a Zone parameter also passed to the routine, this will determine how close the Z axis must be to the target before the horizontal move is triggered. (I have attached a basic diagram, the Zone is shown by the circle, I intend for the P&P to follow the curve of the blue line within the circle)
In short, I want to cut the corner without stopping.
Has anyone tried his before?
I would like to know of a good method to determine when the z axis enters the Zone, I have considered Comparing the Position feedback of the axis but wondered if there was a better method of doing this. Bear in mind that the Z target position and Zone could change each time the routine is called.
All axis are configuired as a coordinate system.
All help will be greatly appreciated.
Hi All
I have investigated further and learnt I can achieve this using blended moves.
For my appliaction I would need to use a Termination Type (6) : Command Tolerence Programmed.
However I do not have all the fields on my MCLM as displayed in the manual.
Therefore I cannot enter the Command Tolerence for the termination.
My MCLM is on the left Manual on the right, I have circuiled my missing fiwlds in red.
Does anyone know how I can enter these fields or why they are not appearing
Good Evening Everyone, I am attempting to monitor the level of hydraulic fluid in a tank. The tank is 50 gallons. For insurance purposes we need...
4,209
Hello: We use submersible pressure sensor in oil tanks to monitor the level in the tank. We also have a routine the will estimate the oil...
1,409
Hi, Does anyone have any experience with hydraulic fluid static electricity affecting electronics?
1,789
Working on an industrial wastewater treatment plant... Do any of you have experiences with these? I'm changing our input signal from a...
18
7,018
I know we should use gate valves but according to the boss "we already bought these orifice plate unions and have put pipe marks on them so they...
49
12,791
