CC-Link Setup With Mitsubishi Melsec Q Series PLC
danplc
Oct 2009
California
Hi All,
Today is my 3rd day of using PLC, so I please bare with me. One of my goals is to hook up a device (CC-Link interface) to the QJ61BT11N CC-Link module and be able to read the devices input/output signal.
So basically if the device outputs 'high' I can use this to turn on one of the LEDs on my QY10 modules. Similarly, I want to send some input signal from QX40 module to the device.
So can anyone show/tell me the following:
1) GX Developer Settings
2) How can I map the Inputs/Outputs from the device to RX,RY,RWw, RWr registers of QJ61BT11N
3) How can I map/relate the RX,RY,RWw, RWr registers values to X, Y on my QY10 & QX40 I/O modules via CPU.
4) An example program showing similar will be even better.
I have attached a picture that shows a rough idea of what I am trying to do (I have only one station). I will really appraciate your help. Please feel free to correct me if needed and ask for any additional materials.
Dan
Thanks Dariush. I figured that out. Right now I am more interested in how to do the programming and signal mapping. Thanks once again.
Does anyone here have experience with the new GuardLink safety relays? They look like a dream to troubleshoot and work with since its just a trunk...
1,228
Hi, has anyone had experience setting up the hardware config for the these balluf blocks? I have the GSD file installed but unlike S7 classic I...
2,832
Dear Members, now I'm working with Mitsubishi PLC QO2HCPU and Master CC link QJ65BT11N, Initially I'm already transfer all the network parameters...
5,065
Trying to setup a CC Link network on a Q02 with QJ616BT11N and a FX1N with FX2n-CCL, failing badly. What settings are required in the Q series, I...
4,262
Good afternoon, I have a problem communicating with a system, I will explain it briefly. I have a HIS -ML17- CTBH monitor connected to an...
16
459
