Cellular Modem to SLC 504 via serial port
RKaighen
Mar 2008
Kansas City
Greetings:
I am trying to connect, via cellular modem, to existing SLC-504's located onboard ocean going vessels within cellular reach. These 504's, as you know, use a serial port for programming and troubleshooting.
We will have a mechanic come onboard, do his thing, and temperarlly connect this cellular modem to the SLC 504, via a straight through serial cable, for us to access over the internet from our laptops. SLC 505's use an ethernet connection and have no problem.
Using RS Links I setup a DF-1 driver using a assignable com port, COM15, 19200, N, 1, CRC, Full Duplex. I am using a Virtual COM Middleware application called "Serial-IP" from Tactical Software and set it up for COM15, using the cellular modems static IP address and port number 2222 (SLC504's serial port?)
The cellular modem is a AirLink Raven X configured for TCP Auto Answer which should accept the incomming data from the middleware, and convert the ip traffic back to serial for the SLC504.
I cannot get RSLinxs to connect to the modem. It browses and cannot find same. I can connect to the modem using the software for the modem, Wireless Ace 3G, but cannot get to the SLC 504 via serial or with RSLinks.
Anybody been here and done that or have suggestions?
Hi all, I have a client that has a water tank with a loop powered level sensor; the 4-20mA loop goes through a telephone line, half a mile away...
26
6,985
I have started a cellular modem network to supplement/replace our Serial radios. First time working on these in real life. I have the cellular...
1,517
Hey guys, I have an SE deployment at a plant where it is monitoring several remote sites that utilize cellular modems for internet connectivity...
2,001
Hi, I made a post about this a little while back but figured I'd remake it as I've made a little progress on it since then. What I'm trying to do...
2,653
Hi, I'm trying to connect to a PLC remotely over the internet. It's a SLC 5/03 connected via serial to a IPn4G cellular modem (Microhard). I'm...
4,441
