Tom Jenkins
I haven't seen this done myself. However, I understand why you would want to. ......
Keith
I've got a different speculation about the reason, and this is one I've done myself - the clutch part, not the "bridge starting, which doesn't look like good practice to me.
Back in the day starting a high inertia load like some fans or pumps, or a load with a high starting torque like a bucket conveyor, caused a lot of trips on the overloads. We didn't have good reduced voltage starting, much less VFDs. Sometimes you just couldn't get the motor up to speed in the ten seconds or so available before the overlaods tripped - the acceleration torque wasn't sufficient. That's often why you would use a torque limiting clutch like the fluid clutch Goody described. My SWAG (Scientific Wild A$$ Guess) is that the contactors bypassing the overloads were there first, and the clutch added later to mininmize the shock load when starting the motor across the line.
