CF Card issue when migrating from MP370 to MP377
Sleepy101
Feb 2012
Cork
I have recently installed a new MP377, in place of an existing MP370. The existing program is created using WinCC Flexible 2008. Recipe and audit trail details are stored on a CF card.
Before transferring the program, I updated all path references from "\Storage Card\" to "\Storage Card CF\". Having transferred the program on to the MP377, I then inserted the old CF card into the new HMI. However now the audit trail functionality no longer works and I am unable to read the recipes.
As a work around. I have copied the information from the CF card onto a usb key and all works fine (I updated all path references to "\Storage Card USB\").
I would like to know if anyone has encountered this issue? Ideally, I would like to use the cf card instead of the usb key. If anyone has a suggestion for what I could do to achieve this I would be very grateful.
Hey guys! I have come across an unique issue. Hoping that I can find some solution here. I want to replace an existing S7-1214 DC/DC/DC plc with...
4,697
I thought it would a simple swap, I connected to NI4 channels to the same channels on the NI8 card and did not add any more input connections...
1,716
Hello, As you may remember, I posted in January about an issue we were having with our micro850 controllers (2080-LC50-48AWB) to operate...
4,286
Hello, We are using 80 micro850 controllers (2080-LC50-48AWB) to operate irrigation booms in our nursery. We are using an analog output card...
7,269
Hi all, We tried to setup the hardware onto a 10 slot rack as follows, PS Slot 0: 5580 controller Slot 1: Safety Partner Slot 2: Safe Inp Slot...
2,750
