Change Ethernet/IP port on Micro850
gottspeed
Feb 2017
Canada
24
Like the topic says, I have someone else behind my firewall running something on 44818 already, and I'm trying to point an external OPC server to a PLC on my desk as well.
I don't see a way to change this port on my processor.
Not sure I understand. Is the someone else using port 44818 on the same Micro850? Or are they forwarding 44818 to the firewall (NAT?).
Can you sketch the relevant players (servers, clients, routers/gateways/firewalls), including the existing 44818 server, and on which processor you want to change the port?
Here is me again with a question that I am suspecting the answer is NO I have a 1769-L33ER that already has some Ethernet/IP devices attached...
4,364
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
857
A customer has a stamping press that has 2 DeviceNet nodes going to a DeviceNet control card in a ControlLogix rack. Older ControlLogix, L55...
41
15,119
I am attempting to change the IP addresses on a machine that we have. The reason is that we have several machines with several different IP's and...
2,331
Hello! I need to know if its possible to transfer data between two PLCs that are on the same ethernet network but NOT contained within the same...
3,421
