Sean Teague
I am attempting to change the IP addresses on a machine that we have. The reason is that we have several machines with several different IP's and id like to have a common IP (192.168.1.1) for all processors. (our IT dept. does not like giving admin rights to everyone to be able to change adapter settings)
anyways,
the machine in question had the following:
Processor
HMI
2 Cognex cameras
2 Torque Drivers
1 Robot
1 IAI MSEP Module
I am having problems with the robot and MSEP module.
They communicate with the PLC thru a ETHERNET_MODULE generic ethernet module in the network tree in the program.
What i have done is:
go offline, change the IP address in the ETHERNET-MODULE
then redownload
then i went to the devices themselves and changed the IP address to match
but, I get the little yellow triangle on the ethernet module and it says its faulted.
Do i need to delete the ETHERNET-MODULE all together then create a new one with my new IP? or is there something else im missing?
I can change the processor IP, hmi IP, camera IP's and torque driver IP's with no issues, but the hardware that is communicating thru the generic ethernet modules is not communicating after the change.
anyways,
Processor
HMI
2 Cognex cameras
2 Torque Drivers
1 Robot
1 IAI MSEP Module
then redownload
