Change the physical order of EtherCAT slaves
Aug 2002
Manchester
527
Hello
Generally, the order of EtherCAT slaves in my configuration matches how the slaves are physically connected.
Before I wade through a million settings, is it possible to give addresses to each slave, so I can happily expect to see them in any order?
I can certainly assign addresses, but thus far the physical order seems to be fixed.
Thank you
Pp
Hi, the last two times I used etherCat I had to address them in my tree to match the way they were hooked up. In a sense I could not connect them (like a star configuration) it seemed I had to connect them in a (linear ) fashion. What setting changed this I am curious.
Thanks.
Hello Bill
EtherCAT still requires the linear topology; you can't 'star' without using a branching unit, or also called an EtherCAT junction (it looks like a switch, but it's not a switch). They aren't transparent to the network, either. The need to be part of the configuration.
My Editor (Codesys V3) has a facility to write a specific EtherCAT address to the slave's eeprom. In my case though, one of the slaves had address rotary switches and these over-rode the eeprom setting.
Settings were as-you'd-expect after this. Let me know if you'd like any screenshots (if Codesys V3 is your thing)
Pp
Hi, I am using vijeo designer v 4.6.. Now in my HMI program i was supposed to change a screen whenever user switches from Manual mode to Auto...
1,802
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
221
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
110
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
231
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
87
