When properties window for the image pops up, double click on the image, you'll be able to select a custom color.Hi all,
When selecting an image from the Symbol Library in Crimson 3, you are offered a set of pre-colored symbols, but I cannot find a way to define my own colors, as in Crimson 2.
Any ideas?
Thank you!
Are you sure? If I double click on the image, the "Adjust Image" window appears, and there's no way to select colors on there.When properties window for the image pops up, double click on the image, you'll be able to select a custom color.
Elcan, I apologize for the false info.Are you sure? If I double click on the image, the "Adjust Image" window appears, and there's no way to select colors on there.
That's what I've been doing, but I am not enjoying it!A work-around (if the symbol exists in the old Symbol Factory) would be to use C2 to put the image on the clipboard and then paste it into C3.
