Charging and discharging battery
Steven01
Oct 2015
Prague
25
Hello,
I have been developing a control software for charging and discharging battery in a dc grid. The system consists of:
01) Three phase alternator with three phase diode bridge rectifier at its output (nominal power Pan)
02) Load with variable power consumption (current power consumption Pl)
03) Bidirectional battery charger
04) Battery (current charging or discharging power Pb)
(please see the attached circuit diagram)
The main goal of the control software is to determine the charging or discharging current of the battery and send this value into the battery charger. The logic behind this is following
01) if Pan > Pl then Pb = Pan - Pl > 0 and Icharger = Pb/Vdc_bus > 0
02) if Pan < Pl then Pb = Pan - Pl < 0 and Icharger = Pb/Vdc_bus < 0
The problem which I have been solving is how to evaluate the above mentioned power balance in case I measure only the dc_bus voltage (Vdc_bus).
I have started with a PID controller which maintains the dc_bus voltage at nominal voltage of the alternator and produces charging current for the battery charger. This idea works only in case the Pl = 0. In case the Pl starts growing up the controller forces the charger to start discharging
the battery resulting in equilibre state when the alternator operates with Pa < Pan and the battery is being discharged (which is of course undesirable state).
The question which I have is whether you mean that it is ever possible to determine the charging/discharging current based only on the dc_bus voltage?
Ohm's Law...
Let's say you have a resting voltage of 20v. If the battery's internal resistance is 1 ohm, and you charge, the resulting voltage may be 21v, so you have 1v drop on 1ohm, so 1 amp... The same in reverse for discharge. 1 amp would be 19v on the battery terminals.
This is for Wolfy... and anyone else that might be interested. A couple of weeks ago, Wolfy sent a PM to me... "Wolf here, I was wondering if...
13,506
I have a remote PLC (Micro800) that is doing some temperature monitoring and reporting on hourly intervals via ModbusTCP to our DCS. It will be...
764
Got a new Galaxy S5 company phone today and the wireless charging is wonderful. Why don't more things have wireless charging.
2,875
What we call "Supercharging" is using a 460 VAC VFD with a mtor wired for 230 VAC rather than 460. And the VFD has to have a HP rating of twice...
36
12,492
Anyone run into this? Had a CLX get bricked during a flash upgrade and our distributor said AB wanted $1,300 to fix it. Our PLC contact from...
24
8,239
