Power Supply Charging for remote PLC
dburnum
Oct 2008
SW Kansas
163
I have a remote PLC (Micro800) that is doing some temperature monitoring and reporting on hourly intervals via ModbusTCP to our DCS. It will be used intermittently and most likely shut down during evening hours. There is no utility power near its intended use are, so I was thinking of powering it from SLA batteries on a "rolling cart".
While the system does only pull 0.2A @24VDC, I plan to put a small solar panel of 15-20w to help keep batteries charged and would like to also be able to wheel the cart to an outlet, to also be able to charge batteries if the need arises.
My issue is trying to source a small 24VDC battery charger that can accept input from a solar array and/or from 120VAC and will satisfactorily monitor the battery charge.
I usually don't put together remote systems like this and am curious about what others may have done in the past. Any ideas on a possible charging system that is small/robust?
0.2A 24VDC sounds like light duty for a laptop charger.
It should never be connected to, in parallel with, etc. the solar charger, as @mobil1syn says.
Since this is being wheeled around to charge from the mains, one plug from the laptop charger, one plug from the solar charger, and one jack to take one or the other should do the job.
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
204
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
579
I have Rhino 120 to 24 dc power supply and it has 2 Positive and 2 negative terminals on the DC side but no ground terminal. Should I connect one...
435
We've still got a ton a PLC 5's installed and running. We lost a 1771-P7 Series B power supply. There are a lot of 1771-P7 series D power...
237
Long ago, it was often a customer spec to always use a transformer for isolation of the control circuit from the rest of the equipment. For 24vdc...
678
