Dear Experts
We are using 3 control logix systems (3 controllers for three different areas) on a cement plant. On two Ares tags are almost 4000.evry thing is fine but on 3rd area tags are approximately 8500.System details are as under
WonderWare "Intouch" MMI communicate with
> controllogix5555 through Ethernet 100mbps "1756 ENBT Module" on
> "DASABCIP"
> protocol but controllogix 5555
> M16 controller give error message "CIP ERROR CODE 0020 Insufficient
> resources" for which I had searched all the manuals and help but
> didn't find any thing about it except this error code in help but with
> out any details.
> This message appears when number of communication tags exceeds from
> 4500 approx and our requirement is 8000 communication tags. This error
> disappears if we reduce number of tags from 4500 or if all the
> hardware "Modules" is not configured.
> Time overhead slice is 21% for project another also I have noticed
> that when we configured our hardware with RSNetworx for controlnet
> then Processor "Estimated I/O Memory" consume all the memory allotted
> for it.
> Details of Memory are below
> Total 229,376 bytes
> Free 6948 bytes
> Used 222,428 bytes
> Max used 222,428 bytes
> Largest block free 6948 bytes
> Estimated Data & Logic memory
> Total 3,702,784 bytes
> Free 3,463,616 bytes
> Used 239,168 bytes
> Max used 239,168 bytes
> Largest block free 3463616 bytes
> Estimated Logic memory
> Total 4,194,304 bytes
> Free 3,255,940 bytes
> Max Used 978,364 bytes
> Largest Block free 3,255,940 bytes
If we decrease our logic (tags are almost 4500) then system works but we have to run the plant using 8500 tags.
We had also increased the NUT time to 100msec & RPI to some different values but problem is still there.
How can we overcome this issue? Is this due to less remaining memory in Control logix processor?
Waiting for your reply
> "DASABCIP"
> out any details.
> for it.
> Total 229,376 bytes
> Free 6948 bytes
> Used 222,428 bytes
> Used 239,168 bytes
