citect addressing with compact logix - HELP
EICS_2
Mar 2015
Melbourne
49
i need some urgent help to address a compact logix variable in citect, i have established comms to the processor , just need to get the correct address syntax.
my variable is a floating point (Real) and its FT115.PV in the processor as a controller tag How do i address it in citect?
Check in the AB driver help tag addressing syntax is there.
also is the tag Controller scope in the PLC?
if using the ABCLX driver replace "." with "/", "[]" with "{}"
Greetings, How should I refer the variables that come from Unity Pro as tags in Citect SCADA 2016? For instance, I want to import some tags...
1,970
How do you refer the variables in unity pro by tags in Vijeo Citect. I know that %I and %Iw can be represented as %M. For example %M10001 would...
1,795
So I have need to display volume and run times on my screens for some equpiment. I recently got some help from support but things are still not...
11,536
Hi I am new to Citect Scada where i used to do industrial automation project with HMI only. How can i refer to the addresses in the unity pro...
3,603
Hi Guys, currently I am working on Citect Scada project where i am using AB plc to connect with SCADA. now, i am finding problem with...
17
20,628
