Citect beginner
ALAN001
Apr 2010
UK
30
Have only just started to learn Citect SCADA and have only done a basic course so far and cant apply a TAG value to a file name for individual file storage.
So
o_O
Thanks for the reply tragically 1969
The problem I am having is trying to put a TAG value into a file save function to create individual file names, rather than creating a report and ending up with one great big file.
Reports with citect are fine unitil they get to big to open with PageRichTextFile function to which I have found.
I hope you can help
You still are not maikng much sense to be honest, describe step by step EXACTLY what are you trying to do.
What is the limitation you are finding with the reports ?
If you want to record data for review in Citect look at using trends, you can export these to .CSV files or straight into Excel
Do you just need to get data out of Citect, you could use DDE straight to Excel.
Right, just read your other thread, think i know what you want to do, dont know why you think you need to do this to store tag values but hey, thats your choice
To add a number to the filename you just need to add the data you want from your LONG value to your filename, so you could do something like this:
filenumber is you LONG data type which contains the number or data that you wish to append to your filename
IntToStr converts a number to a string then it just gets added to the string with the + symbol.
Just run the function Copy() from a button for testing and then you can decide when this needs to run.
Hope this helps
FUNCTION Copy()
FileCopy ("C:\Data\Report.rtf","C:\File\Storage\Report"+IntToStr(Filenumber)+".rtf" ,0)
END
Thanks for the help there tragically1969
Thats exactly what I needed to do, Its so every time a batch report is created it can be saved wuth its own batch number and found later via the batch number
Thanks again
Thats write I have used FormNumPad funtion to create a file recovery number and a PageRichTextFile function to open the file again with the same syntax as tragically1969 gave me. just for those people who read this thread in the future
Thank again
tragically1969
I have been trying to create a cicode function to say M100 comes on to do the FileCopy function but having no luck so far.
Was going to use an event but not enough room in event box.
Any other possible solutions would be much appreciated
Lots of ways to do this and it depends how long M100 will be on for but you could just run the function from the event with the trigger as M100, it will get checked every second.
Cant do an Event as the syntax is to long to go in the event box hence the reason trying to possibly use cicode
Alan
You are misunderstanding, use the event to call the function, you dont need the full syntax in the event, in the event just have Copy() or whatever you ended up calling the function, when the event runs it will run the fumction.
Only just had a chance to try this, It works fine.
Thanks for help hope I can be of some use one day
Can anyone guide me how to use a citect scada/explorer as I am new to PLC . andd We schneider make PLC whose programming I want study for our plant
2,348
I am new to Citect but have managed to teach myself the basics. I understand Citect explorer and graphics builder. I have created a project...
5,197
30
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
58
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
70
