Citect control of PLC
mjm
Aug 2005
Albuquerque, NM
I have a question. Once I finish this Citect GUI, and my associate has finished his programming of DirectSoft. How do we make them communicate?
DirectSoft apparently runs on bit numbers. Will I have to enter all of his bit numbers in the Citect address area of the variable declaration in Citect so that Citect will send the proper command to the proper bit???
I am not understanding this whole concept very well.
How else can Citect know where to send the wright data? Unless you're able to export the address list of the PLC to Citect, that's exactly the way to go. You can however import addresslists made with Excel (or any other spreadsheet capable of saving DB4-format files) into Citect.
Kind regards,
You can use digital bits, integers, real (IEEE754), arrays - really whatever you want.
For example, with Omron PLCs one can use CIO area (Common I/O area) DM (data memory/register), HR (holding relays - memory retentive), timers, counters. As an example, a digital bit for Omron is recognised as 100.09 (channel 100 bit 9), a data memory as DM1000 (register 1000 - BCD or integer).
Just watch out as Citect is set up as even boundaries for words. This means that if you are reading double length (32 bit) words they have to start with an even number.
Appreciate it....
Thanks folks... I thought that was the way it was going to be... I just wanted confirmation on my ideas.
Appreciate the feedback... I am so glad I found this place so that I can get help from people who have already been around the block a time or two.
mj
Hi everyone, I am trying to create a medium sized Citect SCADA project utilising a Control Logix PLC. I want to adopt good practice from the...
2,358
Hi Friends Please I urgently need help on how to configure PID (Reverse and Forward acting)control in Vijeo Citect SCADA Software for an LCV/LIT...
1,522
I'm a bit new to Citect and SQL. Having trouble using the SQL Table Control. I can get a table but when I want to retrieve data from the table...
2,945
Hello everyone ! I am trying to restore a citect project on a different computer.However when I try to open a specific page with graphics builder...
6,982
Hi, just starting to learn citect Scada, and im trying to connect it to the control logix, i have followed all the instructions in the "help"...
3,914
