Hi Chelton, thanks for the reply again. l have tried your example but are you not talking to the PLC via a 1747_KE (using KE500 protocol) and not direct to the CPU serial, as l tried (with driver removed from RSlinx) and it comes up with "bad" comm's. I have also tried different combinations of Board type and I/O Device Protocols with no luck. Comes up with "Ports Board used with different protocols.
In changing CPU Ch0 to half duplex l take it that l need a Board type suitable for half duplex and/or the same for I/O device protocols but in my drop down menu l cant see/find one. Also if l use the wizard it does have a half duplex driver for the I/O but this does't enable comms either. Please find attached my options.
Any hints? Regards
Any hints? Regards
