Citect - Ungroup & Regroup without losing properties
ongzy
Dec 2010
Selangor
100
It takes up a lot of time to edit the grouped objects of a finished project as it has a lot of modification to do.
Anyway we can ungroup, edit then regroup them without having to reinsert the group properties?
This is something I've only discovered recently, hold down the "Ctrl" button while clicking on the object in the group and (usually) you get to edit the properties of that object.
I say "usually" as it is not infallible when you have nested groupings - then I just have to use the old, slow method!
Good luck.
You cant ungroup and regroup without losing properties, but you can get to the objects within the group and edit the properties. From the top menu bar, I think it is under tools there is a selection 'go to' (I think) clicking this will show all the animation points on the page, you should then see the groups expand the group and select the object within the group and edit its properties
hope this helps
Mmmmm, so you can!
Pity everything is referenced by its AN number. :unsure:
However, this can be found by selecting the Access tab of the properties of the original grouped object. (y)
Thanks.
If you want to edit a property of an item inside a group, the 'CTRL' method is best.
However if you want to edit something that is not a property (such as position) you really need to break the group up. I usually keep a duplicate of the original group so i can just paste the properties of the group back in.
Good luck.
hope this helps
You guys are equally awesome.
This is indeed a great help, thanks!
Ctrl method is faster, but no harm learning more.
Let's hope citect do something about it :)
Thanks for this foot note.
54
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
81
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
73
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
76
I have a running backup of Citect and plc and I want to make a spare PC station so I have installed the win XP and somatic net v6.0 and import the...
126
