Citectscada v.7.40 a problem with Username
Go into the Computer Setup Wizard from Citect Explorer (Tools -> Computer Setup Wizard). Go through and see what the settings are for each part. Check in particular:
Computer Role Configuration (is it running multi-process or single process?)
Network Model (is it standalone or networked?)
Server User Configuration (is it set to Default Server User?)
At the very least, it should give us a better idea of how your system is set up.
[LAN] SecureLog is default (1) . I will try setting to 0 and test if it works. Do you know if there are any fixes about this in Service Pack 2?
I have never seen the issue described so cant really comment on the fix.
Check the KB articles on the Citect SCADA website to see if its described, there may be a hotfix for the specific issue.
From Service Pack 2 Release Notes:
"59315 - Log device command field of {USERNAME},{FULLNAME} outputs SYSTEM for some alarm state changes
When logging alarm state changes to a device, the USERNAME and FULLNAME fields were not always populated correctly. These fields now contain the correct information."
In my case always incorrectly. Maybe related to locale. I don't know how to install this with a hotfix installed(required).
Hi there. First of all I'm kinda new to CitectScada. I'm trying to make a supergenie to call a cicode function. Was hoping to use the same...
1,680
Hello, I am having some problems connecting these two softwares. I will explain: I have a program in Unity Pro, i tested and i have it in...
6,685
Hello everyone! I have a question about the allowable syntax for an expression in CitectSCADA. If I wanted an advanced alarm to trigger based on...
931
Hello, Just wondering if it is possible to make internal CitectSCADA project tags available to an OPC server. (Schneider OFS). There are...
918
Hello, This may not be the place for this but im curious of anyone has worked with CitectSCADA 2018 and windows sessions. Any feedback would be...
1,584
