'Click' I/O Module Availablity...
Eric Nelson
Apr 2002
Randolph, NJ
4,346
I just finished the schematics for a little 'rush job' we're doing. When I went to Automation Direct's website to order the PLC components, I discovered that an I/O module I need is backordered until after Christmas!... :rolleyes:
I 'planned' to use a C0-16ND3 16-point input module, but the expected ship date is Dec. 28th. Their C0-16NE3 16-point AC/DC module would suffice, but that one is backordered until January! From past experience, I know that their backordered stuff often shows up sooner than their 'expected' ship dates, but I don't want to count on that.
Worst case, I can use two C0-08ND3 8-point modules (in stock), but I'm a bit tight on space, so I'd rather use the one 16-point module.
Just wondering is someone here has a spare C0-16ND3 on the shelf they are willing to part with?... :confused:
Also, while I'm asking... I also need one C0-08TD2 8-point sourcing output module. These are currently backordered with an expected ship date of Dec. 5th. That's not horrible, but if anyone has one of these too, I'm interested... ;)
-Eric
Hi Eric,
I will check in tomorrow.... I have a couple of IO's just not sure what they are
I will send you a email if I have them
Click Plc/analog 0-10 v output module/0-10v dimmable led driver. I made a program using multiple drum to create by increment fade in and out led...
1,412
Hi All I'm trying to add an analog input module to my Click plc to attach some potentiometers to. I can't seem to get any data in my system...
1,995
What is the simples way to do a double click of a button in a ladder logic. New here and I hope this has not been asked before.
22
539
I have a program that I am gradually piecing together (my first program). There are 4 cascading timers that turn Y001 and Y001 + Y002 on and off...
547
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,094
