CLX/Controlnet warnings when saving CLX program
randy741985
Oct 2006
US
154
I have CLX Processor using Controlnet, I have 7 remote Point I/O
modules everything is fine on the Controlnet network, But when I go to save the program I have 7 Warnings all refering to each Point I/O Module warning Being...
Controlnet Connection not Scheduled.
Everything is running fine but my question is there a way to clear up the warnings without taking down the network, Correct me If I am wrong, You cannot reschedule the network while running.
Thanks,
Thanks,
What version of Clgx are you using? I recall seeing this kind of message in version 13 whenever the controlnet *.xc file was linked with the Clgx 5000 file using the 1756-CNB properties tab.
Yes you are correct, rescheduling the C-net requires the plc to be in program mode. If anything, this is the safest method.
I'm trying to set up a MSG path between a CLX processor on ControlNet to a PLC-5 processor on DH+ and I cannot figure this out. The first attached...
1,296
I was troubleshooting an apparent loss in communication between a 1756-CNB and a ControlNet module (plugged into Brabender Controller). I...
1,927
I'm going to be doing a project and need 24 120 VAC inputs and 16 relay outputs. On Point I/O I was going to use IA4 and OW8 modules. On Flex I...
3,757
Trying to perform scheduled ControlNet connection between 1747-SCNR/A FW Rev 1.4 and 1756-L55/A !756-M12/A Revision 12.25. Following example in...
4,107
4,496
